Hi not sure if this is a Hardware or software so here goes
i bought i new laptop today 256 memory and 1.3 cpu
i have noticed it works great with virtual DJ but it takes 10 seconds for the MP3 to completely load or to Analyse it?
anyone got any ideas? could it be Hard drive rpms etc?
thanks for any advice givem
Rossy:):):)
Rossy:):):)
geposted Thu 21 Apr 05 @ 12:49 am
Memory and CPU of your ?*new*? laptop is most likely your problem.
Way under-powered.
cstoll
Way under-powered.
cstoll
geposted Thu 21 Apr 05 @ 5:10 am
That's enough cpu, but you should really toss some more ram in there. I'm currently only using a 1.2ghz processor with the only problem being that I don't have enough cpu to both process the sound (vdj) AND record it by running my master back into the computer.
VDJ alone runs just fine on this cpu that is probably the grandfather of what most of you are using. =)
geposted Thu 21 Apr 05 @ 6:09 am
rossy......
you have to keep your pc verry clean.....if you look around in the forum you find enough for the best settings.....I also have 256 mb ram...and when i keep my pc clean it runs like hell...
no problems for me.....
look at my blog....you can read the best settings for a pc when it gives problems...
good luck...
good luck...
geposted Thu 21 Apr 05 @ 9:24 am
Your tracks will load much faster after analyzing them.
If you want uncompromized performance put a gig of premium ram in your system.
Even my back up with 512 is slow to load folders.
geposted Fri 22 Apr 05 @ 12:27 am
Hi thanks for all your replys
i upgraded the memory to 500mb
its still slow even after analysing them all
its a new laptop with clean install
only thing i can put it down to is the Hard drives rpms wich is pretty slow
Thanks guys
Thanks guys
geposted Sun 01 May 05 @ 11:57 am
