Topic: Pitch Reset- extend time???
Hi does anybody know of a way to increase the time that the pitch reset works as sometimes its a bit harsh and the object is so that it doesnt notice when a track is playing....
geposted Sat 19 Sep 09 @ 9:28 am
SupaconPRO InfinityMember since 2005
This will have the answers you are looking for:
http://www.virtualdj.com/wiki/VDJscript_verbs.html
pitch_reset : slowly brings the pitch back to 0%. you can specify the speed in % per second (default 1% per second): 'pitch_reset 5%'
So just create a hotkey or something and give it a small value for pitch reset like 'pitch_reset 0.3%'. In VideoVision I used a low value like this on the pitch reset button for gradual changes, and for rightclick I used a high number for quick resets.
geposted Sat 19 Sep 09 @ 3:18 pm
Ok got it but how do i change the pitch value by 0.3%. i tried to set it up in the mapper but no ption to change the value
geposted Mon 21 Sep 09 @ 7:45 am
Do you use the pitch reset in skin (with mouse), or do you use pitch reset at a controller?
geposted Mon 21 Sep 09 @ 10:15 am
KiyosiPRO InfinityMember since 2009
pitch reset in controller with RMX.... i hate manually doing this!
geposted Sun 09 May 10 @ 4:56 am
Cuando coloco una canción que empieza a reproducir este botón (pitch reset) me aparece automáticamente en un valor 7.50 % y hasta mas alto. Como colocaría esta función para que no funcione así automático que siempre este 00.0 % cada que las canciones inicien?
geposted Wed 27 Sep 17 @ 2:13 am
