Forum: Old versions
Topic: Which Macbook Pro?
empyreHome userMember since 2009
13" or 15"?????
Looking on running VDJ on MAc or Win7 using bootcamp or parallels...
Either way just looking on opinions in screen size
geposted Mon 21 Sep 09 @ 10:08 pm
Do you want to use video? if yes, buy the model with a 2.8 core 2 duo cpu and the 9600GT or an older model with the 9600GT (video card), if you are not going to use video it's a matter of screen and the laptop size that you prefer.
geposted Tue 22 Sep 09 @ 10:47 am
It is also a matter of whether you want to run firewire or use express cards. If so, you will need a pro. the 13" is USB only.
geposted Tue 22 Sep 09 @ 12:50 pm
The Macbook Pro 13.3 does have a 800 firewire port.
#two USB 2.0 ports (up to 480 Mbps), one FireWire 800 (up to 800 Mbps), SD card slot
geposted Tue 22 Sep 09 @ 4:42 pm
