Topic: Help with my sound card???
Hi Guys.
Im trying to set up my sound card. I have a Creative Audigy 2 nx sound blaster. conected by usb. the card supports 7.1 surround sound. I am just wondering if i can separate the left deck and right deck in to 2 channels on my mixer through this card?? can i have the left deck through the front speaker output and the right deck through the rear speaker output??
Cheers
geposted Fri 22 Apr 05 @ 11:23 am
djjbPRO InfinityMember since 2004
that's right........
the left deck through the front speaker output and the right deck through the rear speaker output is possible....
you select config(or set) - soundcards - advanced config - advanced config then you can select.
good luck...
geposted Fri 22 Apr 05 @ 1:06 pm
sounds exactly like the setting I'm using :) Happy mixing. The previous reply describes how it is configured. It also works by choosing 4.1 soundcard and then choosing your soundcard in the box of your soundcard choices.
geposted Fri 22 Apr 05 @ 2:52 pm
thanks a lot guys. This Forum is a really good help. Thats what i like about Virtual dj. You can get help when ever you need it..
Happy mixing to all!!!
geposted Fri 22 Apr 05 @ 3:11 pm
