Forum: Old versions
Topic: Issue with Virtual DJ 3.4
I removed some old program files which seemed to contain some Virtual DJ files. When I try to re-install and patch, I get the messages "The internal database is corrupted" " Error in the Sound Driver of DirectX and "Invalid skin file (error line%i in the xml." cosecutively. I did some research based on this but it's not working. The VirtalDJ.exe file is not opening.
geposted Sun 27 Sep 09 @ 2:17 pm
When you say "When I try to re-install and patch".
You meen you are using a cracked copy of VDJ.
If you want support on these forums go buy a license.
hi, i need support, i buy the hercules dj console MK2 with virtual dj DJC Edition, but 3 days after using it, i have this error message "invalid skin file (error line %i in the xml)" on my screen, when i start the software. i don't find any solution, and i don't know what to do. please help me
Edited to say..
I see you already found the thread talking about your problem.
