Hope you like my new skin that will be ready the next day, can leave suggestions if I have to add something
SKIN_MAN_SKIN
SKIN_MAN_SKIN
geposted Mon 28 Sep 09 @ 10:33 am
That's a nice looking skin. I would loose the sample buttons in the middle, and add vertical VU meters. Using the v6 code the VUs can now show system output, as opposed to system gain. That is what I would like to see, other wise its a very pretty skin.
geposted Mon 28 Sep 09 @ 11:16 am
Cool skin though, but looks too bright with the white color...
maybe u could add some black to it.
Just my opinion =)
Good work!!
Just my opinion =)
Good work!!
geposted Mon 28 Sep 09 @ 4:56 pm
maybe its a daylight skin!
geposted Tue 29 Sep 09 @ 6:40 am
when it will be released to go down, pretty skin my congratulations
geposted Tue 29 Sep 09 @ 11:17 am
Thanks for the comments, I'm working on the changes undergone by you
geposted Wed 30 Sep 09 @ 10:40 am
felicidades buen trabajo amigo saludos esta chever el skin
geposted Fri 02 Oct 09 @ 7:03 am
Look The new panel
geposted Fri 09 Oct 09 @ 10:31 am
There you go! Very nice... ;-)
geposted Fri 09 Oct 09 @ 10:35 am
geposted Mon 19 Oct 09 @ 3:25 pm
I hope soon to put the skin in the library
for now I leave what\'s coming
MULTI-Instac 6
MULTI-Instac 6
geposted Sat 24 Oct 09 @ 10:28 am
Nice skin dude......
I still think that u should make one with more dark colors
Just my opinion :D
DJ ALEX
Just my opinion :D
DJ ALEX
geposted Tue 27 Oct 09 @ 1:07 pm
I would like to see a all white version or chrome version of the vdj6 standard skin. Is that a available ?
geposted Sun 10 Jan 10 @ 3:25 pm
If you need a all white version to dj in daylight with VDJ, you can use the Skin Resizer tool.
Select the same output width and height as the input width and height.
Use "Simple Resizer" resizing option.
And in the "Options" view, select "make day skin"
This will invert all colors of the skin and make a bright white skin.
geposted Mon 11 Jan 10 @ 1:45 am
WOW...thx...this skin looks so fine....and a little bit of honor
geposted Thu 14 Jan 10 @ 7:25 am
The download link for this skin is not working...How can I download this skin? It looks great.
geposted Thu 11 Feb 10 @ 10:46 pm
that means that the skin it's not available anymore.
geposted Fri 12 Feb 10 @ 12:01 pm
I assumed it was not available at that location. Is it posted anywere else that you might be aware of!
geposted Fri 12 Feb 10 @ 2:28 pm
geposted Fri 12 Feb 10 @ 2:39 pm
Thank You!
geposted Fri 12 Feb 10 @ 4:10 pm
