I really like that skin, but when it goes full screen it just looks like ISH.....
Any suggestions? or maybe who I can contact to make me a skin?
geposted Thu 01 Oct 09 @ 6:15 pm
What skin are you talking about? is it the old scratch version i made for VDJ 4.0? I dont even see it for download anymore. I still have it.
there are 2 ways you could do this one easier then the other.
1. keep the skin the same size as is and make a boarder/background so fill in the entire screen. The browser can be extended also.(easier)
2. resize the entire skin and have the parts like spinners and other things that didnt resize well re-done. (more work)
you can check out my more resent skins that are in 1280 too, they will resize better then a 1024x800
skin.http://www.virtualdj.com/addons/8875/C_E_.html
http://www.virtualdj.com/addons/5884/Turntablist_variations.html
http://www.virtualdj.com/addons/8331/VDJ6_mod.html
I'll even entain an offer to create something your looking for, if you can pull me away from other work. :)
geposted Fri 02 Oct 09 @ 9:30 am
