I use the map listed below and I would expect that when I press the $pitch key that the jog wheel would change the pitch by the specified increment but it only changes in the negative direction. Anyone have any ideas on whats wrong with this?
var $pitch ? param_greater 0 ? pitch +0.01% : pitch -0.01% : jogwheel
EDIT: I found this at the VDJ Script Examples in the Wiki except it was for an endless encoder knob, I figured the jog wheel would meet the knob requirements...
geposted Thu 01 Oct 09 @ 8:59 pm
For a jogwheel, try using param_greater 0% instead of param_greater 0
Alternatively, you could try:
(Use smaller value for finer adjustments, larger for more course.)
var $pitch ? param_multiply 10% & pitch : jogwheel
geposted Fri 02 Oct 09 @ 12:44 pm
Awesome!! I will try this out and let you know how it works out. Thanks mate!!
geposted Fri 02 Oct 09 @ 3:07 pm
Hey jpboggis,
Thanks again. It works great!! Now to fine tune the values...
geposted Fri 02 Oct 09 @ 8:26 pm
Hey jpboggis,
I was playing at a gig and I am not quite sure what happened but my jog wheels got stuck in moving the effect sliders and I could not get them to back to normal outside of restarting VDJ. It happened once while in practice and once last night. Any ideas to what maybe happening?
I tried to map reinit_controller but that didn't release the jogs. Can you think of something that I can map that would release the jogs from the effect sliders? Thanks brotha!!
geposted Sun 04 Oct 09 @ 4:04 pm
How is it mapped?
If you have mapped it to effect active ? effect slider 1 : ... then the problem was most likely due to you still having an effect active. You can see the status of all effects under the Effects tab of the browser.
Also, to avoid this, make sure that CONFIG -> Options -> FX Reset on Load is activated - This will automatically disable all effects on the deck when you load the next song.
geposted Mon 05 Oct 09 @ 1:53 pm
Thanks for the support brotha!! I will try this out and let everyone know what I find.
geposted Tue 06 Oct 09 @ 3:37 pm
