Hello everyone,
Need an advice, I'll appreciate if u can help me..
I've got Hercules DJ console mk2..
I would like to buy Pioneer CDJ-800MK2 (pairs) and a mixer. Can I connect these stuff to my laptop to control them on Virtual Dj?
And one more question.. can I also connect my present Hercules console with Pioneers?
geposted Fri 09 Oct 09 @ 10:46 am
arasnk wrote :
Hello everyone,
1) Yes you can but you will need Pro edition to use TCCD
2) Yes but again you need Pro edtion.
geposted Fri 09 Oct 09 @ 11:02 am
Actually you can:
A) Connect CDJ's to computer in order to control VirtualDj with the CDJ's. VirtualDj WILL NOT control your CDJ's
B) Connect your Hercules to your mixer in order to control VirtualDj.
C) You can use both CDJ's AND Hercules at the same time to control VirtualDj
You can't:
A) Control CDJ's from VirtualDj
B) Connect your Hercules on the CDJ's
C) Connect your CDJ's on the Hercules
D) Control CDJ's with Hercules or control Hercules with CDJ's
You can't:
geposted Fri 09 Oct 09 @ 11:26 am
PhantomDeejay wrote :
Actually you can:
You can't:
You can't:
WHAT???
Only CDJ400 can be connected to your Computer and he said CDJ's 800MK II
Conecting your MK II to a mixer will alow you to use a external mixer but you still have to use the MK II to control the internal fader
You are correct on this BUT only TCCD can be used when set up this way!! cannot go live...
as for your next row of answers it makes no sense?
geposted Fri 09 Oct 09 @ 11:42 am
I don't think PhantomDeejay knows that the Hercules Dj Console can be used as a timecode sound card too.
has anyone had experience with using the hercules mk2 as a sound card? if yes, is it good?
geposted Fri 09 Oct 09 @ 3:08 pm
pay for software or reg your copy to get help
geposted Fri 09 Oct 09 @ 4:08 pm
Why? I'm asking this to see if I SHOULD get VDJ. Why would I buy the software first and then find out what I bought was bad?
geposted Fri 09 Oct 09 @ 5:08 pm
The MK II is a good solution for TCCD in small settings...like a bar or small club... I have both the MK II and the RMX and use either for small venue's
simple quick and to the point!!! with either!!
geposted Fri 09 Oct 09 @ 9:03 pm
You thin it will be good for timecode solutions madman?
Thanks!
Thanks!
geposted Fri 09 Oct 09 @ 9:48 pm
You already know the software is good and you know it's worth it. I have helped you with configuration myself. Look, you are a smart kid. Don't play someones intelligence when you know better.
It's always better to support the software you use rather than use illegal copy then ask for help when it does not work the way it should. You get more help and respect on the forum, free updates, free plugins and everything else that comes with a LEGAL copy of VDJ.
geposted Sat 10 Oct 09 @ 9:58 am
I am having problems connecting my Pioneer CDJ-800MK2 to my system. I need Help.
I have a legal copy of vdj 6.5. I have 2 cdj-800 mk2 a numark x6 mixer and dj console rmx.
I tried ti run timecode but I ame not getting the right settings. I download the audio file for the time code cd's but I cant no more than 2% quality. I have tried vdj cd I have tried serato cd and other settings for the sound , what am i doing wrong ,somebody help me please
geposted Fri 25 Dec 09 @ 8:41 am
Hi. I am having a problem with my cdj900 and virtual dj. Basically the sound is coming through my cdj's but I cannot control the tracks using decks. Any ideas how to enable this option?
I'll appreciate your help.
Cheers
Cheers
geposted Wed 22 Sep 10 @ 10:38 am
hey wondering if you can connect the pioneer cdj's 1000 mk2's to vurtual dj via a laptop...been told it isnt possible but some1 with a bit more experience in the equiptment field told me it is ....please help...thanks ...
geposted Tue 03 May 11 @ 3:56 pm
Any standard DJ CD player such as Pioneer CDJ-1000 can be used to control song playback in the full VirtualDJ Professional by using timecode CD's.
You will need a suitable ASIO sound card with at least 4 inputs and 4 outputs such as Hercules DJ Trim, Native Instruments Audio 4 DJ / 8 DJ or ESI Maya44 USB.
You will need the full VirtualDJ Professional http://www.virtualdj.com/buy/index.html to use timecode. VirtualDJ Home FREE allows timecode to be tried out for 10 minutes at a time: http://www.virtualdj.com/download/free.html
Timecode CD's can be created yourself using the file downloadable from http://www.virtualdj.com/products/timecode/cd.html - Simply use your CD writing software to burn a couple of audio CD's using this file. You will need the pro grade file for Pioneer CDJ's.
Setup instructions can be found in the user manuals for VirtualDJ: http://www.virtualdj.com/wiki/PDFManuals.html
NOTE: Your computer needs to meet and preferably exceed the recommended specification on the following page: http://www.virtualdj.com/products/virtualdj/index.html
geposted Wed 04 May 11 @ 5:31 am
