Man, I am so confused; the more I read on amps & speaker matching, the more confuse I get. I'm just getting my equipment together for PC DJing at small functions like weddings, and parties at small to medium dance halls. So, can somebody hook me up with an amp and speaker combo that will work well? Budget? About $800 - $1000 total for amp and speakers. Thanks to anyone who responds.
geposted Thu 15 Oct 09 @ 3:19 pm
Amp
QSC GX5
http://www.pssl.com/QSC-GX5-Power-Amplifier-500W-8-ohms
Speakers
Yamaha BR15
http://www.pssl.com/Yamaha-BR15-2-Way-15-Inch-Speaker-
OR
Peavey PV-115
http://www.pssl.com/Peavey-PV-115-15In-2-Way-Speaker
OR
Behringer B215XL
http://www.pssl.com/Behringer-B215XL-15-Inch-2-Way-Speaker-
You could also go with powered speakers like
Behringer 215A
http://www.pssl.com/Behringer-B215A-15In-400W-2-Way-Powered-Speaker-
OR Behringer B215D
http://www.pssl.com/Behringer-B215D-550-Watt-Active-15-Loud-Speaker-
Any of this stuff will do it for you AND fit your budget. If you need more help or info...contact me.
QSC GX5
Speakers
Yamaha BR15
OR
Peavey PV-115
OR
Behringer B215XL
Behringer 215A
OR Behringer B215D
geposted Thu 15 Oct 09 @ 5:06 pm
if you're doing small to medium sized venues, i say you get powered speakers. for the price you can get some great deals used... ie JBLs which sounds good and are loud.
if you really want to go new, i sae you buy the behringer b215as, ridiculously good for the price.
geposted Thu 15 Oct 09 @ 8:22 pm
Thanks guys!! I'll check out your suggestions. Thanks for providing the links; that makes it much easier.
geposted Fri 16 Oct 09 @ 12:51 am
i have 2 gx5 ampl,2 speaker peavey 215 & 2 peavey18 sub,work good.
geposted Fri 16 Oct 09 @ 11:07 am
