can anyone help me.. i click on the cue button but only one spot there.. i know we have the capability?
geposted Mon 02 May 05 @ 10:22 pm
No matter what skin you are using, if it has multiple cue points they are easy to set up. You say that you use the default skin and you already know how to add one cue point. All you have to do is find a place in the track that you want to make a cue point at, push the cue number and there it is. So if you want multiple cue points...push 1,2,3,4 or 5. The cue function has a place to create these points and go directly to them. It's pretty easy.
If you haven't already read the manual try looking at it.
http://www.virtualdj.com/support/manual/
MS
MS
geposted Mon 02 May 05 @ 10:37 pm
thanks madd sound--ill try it later tonight..
appreciate the info.
geposted Tue 03 May 05 @ 5:04 pm
