Again, I'm new with the software, and I'm trying to get some answers to a few questions. Is there a way to search the entire hard drive for songs? And what's the best way to search for songs? Thanks.
Dodie
Dodie
geposted Sun 15 Nov 09 @ 9:39 am
Hi Dodie,
Since you are a new user, have you taken time out to read the VDJ manual fully?
Pages 10 - 12 explain how the search function works and can be found here: http://www.virtualdj.com/wiki/PDFManuals.html
geposted Sun 15 Nov 09 @ 1:49 pm
I've printed and read the manual, but the problem I'm having is the software isn't seeing the entire library when I search. I've gone into the "Config" and had it check, fix and clean the data base, but that didn't seem to change anything. Any help?
Dodie
Dodie
geposted Thu 19 Nov 09 @ 6:22 am
Hi. Maybe you have to add files to search DB. You can do it this way: on the browser, folder browser, you rightclick on the drive containing the mp3, than add to search DB
And you make sure in config/browser the search database option is set to \\\\\\\"add automatically\\\\\\\"
than make sure you have set in view_option \\\"show music\\\" \\\"show video\\\" \\\"show karaoke\\\"
Now you do a search :)
geposted Thu 19 Nov 09 @ 12:15 pm
Right now it seems everything's fine. I've done some searches and have been able to find the songs. Thanks a bunch.
Dodie
Dodie
geposted Thu 19 Nov 09 @ 1:39 pm
