Forum: Old versions
Topic: How come....
VOXDCPRO InfinityMember since 2003
everytime i put in a song that is longer than 10 minutes it wont work. First it wont scan the song, and second if i play the song, it would lock up every 2 minutes. I had the freezing problem before, but now that i bought the software everything runs fine except when i put in a song that is longer than 10 minutes. What do i do????
Thanx.
geposted Mon 11 Aug 03 @ 6:02 pm
jukesyPRO InfinityMember since 2003
What are you system specs?
geposted Mon 11 Aug 03 @ 6:09 pm
DJ CocoPRO InfinityMember since 2003
Check in the options that the "limiter" feature is set (accepts)tracks longer than 10 min.
geposted Mon 11 Aug 03 @ 6:39 pm
Yan-XPRO InfinityHonorary memberMember since 2003
on the contrary I think you don't have enough memory to play long songs so the swap disc is used and you are experiencing freezing while the system is swaping data from virtual memory to ram
geposted Mon 11 Aug 03 @ 6:48 pm
set limiter to 5min or always to load only a small extract of the mp3 file in memory at a time.
geposted Mon 11 Aug 03 @ 6:49 pm
DJ RickPRO InfinityMember since 2003
Yup, it sounds like you definately need more RAM!
I think that i have enough RAM:
Intel IV
1.5 GHz
512syncDRAM
Windows Xp
geposted Mon 11 Aug 03 @ 8:05 pm
have you tried mine?
geposted Mon 11 Aug 03 @ 8:11 pm
What is the size of your hard disk. How full is it and when was the last time you defragmented?
geposted Mon 11 Aug 03 @ 8:26 pm
Dj Coco, thank you very much, it worked. I changed the limiter and now it scans the whole song and it plays perfectly fine. Thank you very much.
geposted Mon 11 Aug 03 @ 8:43 pm
