Forum: Old versions
Topic: quick question: win 7 64bit & asio4all?
jaakkoPRO InfinityMember since 2006
Hi,
I am about to buy a new laptop today which has Windows 7 Home Premium 64 bit.
I have vci-300 conroller and i must use asio4all.
Does asio4all work on Windows 7 Home Premium 64 bit?
Yes or no??
I need answer asap, in next 3 hours.
Thanks!!
geposted Mon 23 Nov 09 @ 6:01 am
look at the page:
Changes since version 2.9 beta 5:
Fix a minor issue with the default configuration in x64
http://www.asio4all.com/
perhaps you find there further information.
it should work but i dont know for sure - ive used asio4all on a Vista x64 and it works but dont know how it perform on Win7.
geposted Mon 23 Nov 09 @ 6:33 am
