Forum: Old versions
Topic: question about screen resolution...
DJAVIPPRO (OEM)Member since 2016
is that ok to work with the VDJ skin internal mixer with the resolution 1280X800 that is the heights on my laptop ?
i didnt understend all the minimize maximize talk in here.
geposted Thu 03 Dec 09 @ 9:31 pm
in the start with 1280X800 the VDJ cpu was bitween 0-2% after 2 hours of cheking with the vdj working on automix the cpu jumped to 20% now im back to 1024X768 for 2 hours and the cpu is back to 0-2% and stays is there explanation to it ?
geposted Thu 03 Dec 09 @ 10:55 pm
Maximising a skin, which takes it beyond its standard resolution is know to impact CPU usage.
Try and find a skin that natively fits the screen resolution your laptop runs in.
Cheers,
Roy
geposted Fri 04 Dec 09 @ 6:36 am
my skin is stuck in minimize so i can't maximize it, so how do you fix that?
geposted Wed 13 Jan 10 @ 4:28 pm
