Forum: VirtualDJ Skins
Topic: one of my samples isn't working
hemanHome userMember since 2005
someone sent me a sample
its the satisfaction BASS LINE ...
when i load it, it doesn't load .....
and it says its empty
can anybody help´.......please
geposted Sat 07 May 05 @ 6:18 pm
claxPRO InfinityMember since 2004
Do you have the same problem with other samples ? On every sample deck ?
Which version do you use ?
geposted Sat 07 May 05 @ 8:26 pm
apopsisdjPRO InfinitySenior staffMember since 2003
What format/extension the sample is ?
Wrong forum btw, this is the skin forum
geposted Mon 09 May 05 @ 8:47 am
no most of them work .........just a few dont work .......i use the 2.01 version .......
.....format/extension ??? dont follow......yah i know its the wrong forum ....but there isnt a sample forum ......
and of my skins arent working either....it says: Invalid skin file( error line 752 in the xml)
i just started using virtual dj ....and i dont spend a lot of time on the comp ......so im not the pc wiz u all are .....so keep it simple please .......thanks for ur help .....
geposted Tue 10 May 05 @ 6:20 pm
yes i have the same problem with other samples...
geposted Tue 10 May 05 @ 6:22 pm
erxonPRO InfinityMember since 2003
geposted Tue 10 May 05 @ 10:24 pm
JeremKPRO InfinityModeratorMember since 2004
First of all, if you are using the 2.01 version of VirtualDJ, i wouldn't be surprised it is a cracked one.
So i don't really know what you are doing on an official forum with a cracked problems.
Anyway you must know that all cracked problems have problems or some bugs in them. The version of 2.01 you are using, i used it a long time ago and had the same problem with samples.
Since that problem i decided to buy Virtualdj and now i'm thrilled when i get every update free. The last update is amazing, you can mix video clips so, you only have one thing to do:
http://www.virtualdj.com/download.html clic here to get the demo and if you like it, buy it, don't CRACK it!
geposted Wed 11 May 05 @ 12:01 am
i dont have the cash for it .....i'm only 15 years old ....
geposted Wed 11 May 05 @ 5:11 pm
