Forum: Old versions
Topic: Can't eject hard drive in bootcamp
Running xp sp2 on MacBook pro 15 inch. Vdj works great after toggling the hardware acceleration slider to the left a bit. Though, most times when I try to "safely eject" my USB hard drive, I get the message that it won't because another process isaccesing the drive. This is when vdj is closed, no antivirus running, etc. Any idea why? Is it safe just to pull the plug at that point?
geposted Sun 06 Dec 09 @ 11:17 pm
hmmmm, any help?
well, i left XP and installed windows 7. no problems now! and video works great!
To Eject.. click on My computer.. High Light the DVD RW Drive (D) look up above the Local c and you will see Eject.
Try doing the safley remove twice until it says its ok to remove now.
