Forum: Old versions
Topic: Error in Sound driver (Hercules DJ Console MK1)
I recently purchased a new MacBook Pro with Leopard OSX 10.6.
Virtual DJ 6.0.2 for MAC was working perfectly for a couple days until one day an error starts to appear stating 'Error in sound driver (ASIO).'
Really annoying as I can't use my Hercules DJ Console with Virtual DJ. I can open Virtual DJ when not using the Hercules but :-/ Thats just lame. I have tried pretty much everything I can think of, uninstall VDJ, uninstalled Hercules CP and reinstalled etc. Then I have updated/removed drivers blah blah. Just nothing is working, I just don't know what changed since me using it fine until this error message.
Does anyone else get this or can anyone help?
Thanks
Joe
geposted Mon 14 Dec 09 @ 11:52 am
do you click on apply in sound settings each time you open vdj.as i believe in all updates you are required to do so so vdj know your sound setting to get started
Is the DJ Console working as a soundcard with iTunes ?
Have you tried updating VDJ to 6.04 ?
I just bought a Hercules DJ RMX today and installed the Virtual DJ LE on my Mac (Leopard OS X V 10.5) following the instructions in the manual and I have the same problem too. I get the "Error in Sound Driver" while Virtual DJ loads and then I can't use the controller. This is a bummer!! Are there any other ways to sort this without having to upgrade to VDJ V 6.0? I would just like to use this to ensure I'm happy with it before upgrading!! PLEASE HELP?
