dot know what to do.
i reinstal 2.06
h e l p
i reinstal 2.06
h e l p
geposted Mon 09 May 05 @ 2:42 pm
- The sound keeps skipping
Version 2.1 has been optimised to take advantage of the new processing power. However, if your computer is too slow or you lack memory, you can still revert to the old behavior by going in the general options and changing the "reactivity" parameter to medium, or even slow.
http://www.virtualdj.com/forum/display.html?topic=11911
geposted Mon 09 May 05 @ 2:48 pm
i have this bug too
changing the reactivity to medium didnt help.
i have a gig of ram though, so...
please help
please help
geposted Tue 10 May 05 @ 2:23 am
do you have timestrech enabled ?
are the decks in beatmatch mode ?
Is it playing at original speed or did you modify the pitch ?
is it exactly 2 minutes ?
on every song ?
on every song ?
geposted Tue 10 May 05 @ 11:04 am
do you have timestrech enabled ? yes
are the decks in beatmatch mode ? no
Is it playing at original speed or did you modify the pitch ? sometime modufy
is it exactly 2 minutes ? no
on every song ? yes
on every song ? yes
geposted Wed 11 May 05 @ 11:38 pm
So disable the time strech = master tempo
geposted Thu 12 May 05 @ 1:54 am
no good - jump also when disable
geposted Thu 12 May 05 @ 12:57 pm
Are you sure you wait for the end of the loading before playing? I prefer advising that even you could play the song
When does the song skip? Give me more details: length of the song, mp3 or wma, when skipping (describe position and visual),...
Which option of memory do you use in the settings? (time)
and please write your computer config inside your blog. Help will be better and faster ;-)
geposted Thu 12 May 05 @ 1:49 pm
and wha tis the skip like ?
1) lalalalala lalalala
2) lalalalalallalalala
3) lalalalala alalala
in other words
is it a pause and songs continues to play where it has to continue
the song just skips to anythor part without pause
or the songs just "mutes" for a while
in other words
geposted Thu 12 May 05 @ 2:02 pm
its skip 1/4 a bit as if i push the 1/4 skip in the remix aria (>)
no pause!
no pause!
geposted Sun 15 May 05 @ 9:50 am
dont get that every 2 mins but exactly the same thing happens when you first move the bass eq for each deck. it has done this in many versions...
geposted Sun 15 May 05 @ 9:55 am
I have this when I search through the database. I click on database. No skip, then I hit the first character -> skip, second character -> skip, third character -> skip, all the other characters it doesn't skip.
I have 51000 songs in the database. It seems that the "search" thread has more priority then the "play music" thread. I also found out that the problem is far more noticable playing audio through Asio then playing audio in wma mode.
The longer I play with VDJ the worse it get
Ewout
Ewout
geposted Sun 22 May 05 @ 4:33 pm
Could you create a blog with you computer config please :-)
geposted Sun 22 May 05 @ 6:14 pm
@djzero, are you sure this bug its still there in 2.1 ?
I had this also with fader eqs (its the same bug) but not with 2.1 yet, but i dont use the software eq so much, can you confirm ?
@Superstorm, its because of the many tracks, but you have right Audio must have the first priority. A possible solution/fix for big databases is to setup (in options) how many characters Virtual dj to ignore (1,2..3) when you start typing before searching and show results.
Example: When you type an "a" first it has no meaning at all in a database of 51000 songs..
- A good idea for the new features forum to ask if you like.
As for Asio its true, it is much more sensitive, i have crackles when use some plugins too (like the 16/32 bands eq's) and also skips when loading songs that not fit in memory.
geposted Sun 22 May 05 @ 6:17 pm
True apopis, very good idea for search filter!
geposted Sun 22 May 05 @ 8:08 pm
i have always good ideas, ...after so many years of using dj software...
geposted Mon 23 May 05 @ 3:43 am
hehe ;)
geposted Mon 23 May 05 @ 3:53 am
listen...
when i put a usb soundcard in my leptop its jump's. only with the card.
what can i do?
what can i do?
geposted Tue 24 May 05 @ 6:30 pm
Did you test your USB port with another device ?
geposted Tue 24 May 05 @ 7:35 pm
