Hi
My behringer bcd2000 is not being recognized by virtual dj 6.0.5!! I have tried the device with ableton live and some other midi software and it works fine but not with VDJ!!! I have a gig in a few days and need a quick fix for this!! Please help me with the solution it must be a vdj6.0.5 error if the device is still working with other software.
thanks
oli
thanks
oli
geposted Thu 24 Dec 09 @ 11:49 am
turn off your comp and plug it into the port that you origionally had it in and start pc if its in origional port the drivers should fire up and load and vdj should work fine.check to make sure that it is selected as audio interface and that it is listed in mappers, try a rescan if not. if it doesent do an uninstall and reintall of the bcd drivers!
should get you up and running again
geposted Thu 24 Dec 09 @ 1:50 pm
Hi,
Your method has not worked. any other ideas?
geposted Tue 05 Jan 10 @ 1:11 pm
I have seen what the issue is now and it should probably be raised as a defect!
When starting vdj with the controller plugged in and turned on vdj sees the controller and you can assign keys.
when I do a rescan for new hardware the controller drops away! surely it should see the controller if it is attached and has previously been used!
hopefully i should be able to work around this now but this should be looked at.
geposted Tue 05 Jan 10 @ 1:28 pm
Always put on BCD first and open VDJ next;
Go to settings, mappers, and enabled MIDI Devices if it's dissabled, try to conect in another USB Port.
Install the following mapper: http://www.virtualdj.com/addons/8710/Behringer_BCD2000_Def___Mapper.html
geposted Sat 16 Jan 10 @ 4:23 pm
