This maybe a simple or a hard topic but it simple isn't working for me.
I have a very powerful computer way above the recomended so thats fine. But it won't take my serial number given when I bought it. from Empire... It was sealed and in a box so I installed it and that went fine then it would not accept the serial but it did for a bit??!! On purpose to test it I wrote an invalid one that was chucked out before the program started! I type the one given in and it loads the program but then quits and gives the msg error with serial!!!
Any ideas as its starting to get anoying. Also the serial will not work on this site when I registered my details!
Any help please...
Sunwise
Any help please...
Sunwise
geposted Tue 10 May 05 @ 2:46 pm
you should contact e-service
http://www.virtualdj.com/support/e-service/
add you problem and you can see there the progreess
geposted Tue 10 May 05 @ 3:47 pm
