Forum: Old versions
Topic: Hercules Mp3 E2.. With Software.. Problem..
I am an owner of the MP3 E2 ...
The problem is that the software that comes with it VDJ edition for mpe e2.. has no config panel.... SO i have some problems.. every time i play the sound card as i play with the sound from the mp3 e2 makes sounds like a hungry stomach or something!!!!!!
I believe that the safe mode is enabled in performance for sound card and i cannot disabled it cause its very limited software.
Is there any other MP3 E2 owner having the same experience?
What can i do to disabled it?
geposted Fri 08 Jan 10 @ 1:13 pm
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
Did you start by updating to the latest version for VDJ (v1.03, available from the DOWNLOAD section of this web site), as well as the latest driver for the MP3 e2 (4.HDJS.2009)?
geposted Fri 08 Jan 10 @ 1:56 pm
OK... the VDJ v1.03 as i see in registry disables the Safe mode.. wich seems that correct the problems.. so far so good Thanks.!
geposted Sat 09 Jan 10 @ 2:36 am
