Is there a way in virtual DJ to record/listen to samples without them going out on the main channel so people on the floor can here it? I often find the "awesome" sample I just recorded sounds really lame with the current song I am playing and would love to be able to prelisten to them through my headphones in the same way you can do when cueing a song.
Any advice?
Any advice?
geposted Sat 23 Jan 10 @ 9:43 am
I don't know about other sound cards but the Virtual Vinyl sound card has a third output channel that you can use just for samples and route to a third line on your mixer enabling you to pre-listen to samples and mix them in as you like.
geposted Sat 23 Jan 10 @ 9:59 am
I run three outputs; deck 1, deck 2, samples & preview
to my mixer..
this is the only way i can think of to accomplish what you want..
to my mixer..
geposted Sat 23 Jan 10 @ 10:38 am
I have the Hercules RMX, would this be possible with that?
geposted Sat 23 Jan 10 @ 11:16 am
AFAIK the RMX is only two channel output. You need three output channels.
geposted Mon 25 Jan 10 @ 3:06 pm
