There is a mapper and definition file in the downloads section which works great, apart from I need to map the Xfader to the video crossfade and cant work out how to do it for the life of me.
Can someone help or does anyone else have a Allen & Heath Xone 3d defintion and mapper file that has the Xfader already mapped to video crossfade.
geposted Sat 30 Jan 10 @ 8:17 am
Are you using v6 or v5 (there is a mapper for each in the download section).
You should just be able to change the mapping in the mapping window to use "video_crossfader" instead of "crossfader".
geposted Sat 30 Jan 10 @ 8:30 pm
I have the V6 version.
Am using the latest VDJ, the problem is the mapper i dowloaded (V6) doesnt have the crossfader mapped in the definitions file.
I want to add the crossfader to crossfade the videos, no audio crossfade which the Xone 3d can do because there is a switch to disable the audio routing whilst still enabling midi to be sent.
If I can add this the mapper would be almost perfect.
The crossfader sends the signal CC5 with values 0 for fully left and 127 for fully right if this helps
Any help would be appreciated.
geposted Fri 05 Feb 10 @ 5:02 pm
The manual has full details about the midi values, I cant upload it here but it can be downloaded from here if anyone can help because this is way beyond me.
http://www.allen-heath.com/uk/dl.asp?file=420
geposted Fri 05 Feb 10 @ 5:37 pm
