I am trying to midi map a Xone:3d at the club. I can't use the mapper from the downloads page since I am connecting the Xone:3d over midi to a audio8 card- at least I do not think I can. Also I do not like the way its laid out. The problem is with the jogwheel and the rotary knob that I would like to use for pitch. If set the jogwheel in the midi mapper to jogwheel +.05 when moving the jog wheel forward or backwards, the VDJ record only goes forward. Do I need to add jogwheel +.05 & jogwheel -.05?
Also rotary knob I use for pitch does not do anything. Is there some different command for rotary knob vs slider like on VDJ 5?
Any examples?
thanks,
David
geposted Tue 09 Feb 10 @ 1:27 pm
If you are using Simple MIDI Wrapper, please see http://www.virtualdj.com/wiki/VDJScript%20Examples.html for details on how to map endless encoders and jogwheels.
geposted Tue 09 Feb 10 @ 1:39 pm
