Forum: Old versions
Topic: Virtual DJ 5.3
Hi
I recentrly trialed the aboved which i found very good and adequate for my needs of Karaoke, being that good i decided to purchase the licience, and since doing so, found that it does not work?
I usually set up, open virtual dj program then plug in my hard drive and then open the ng search which I update and re-index on a regular basis, select the song from there then drag and drop the song into one of the play selections, to date it has been that simple.
Now I have the licience I am unable to do this and don't know how to set the ng search to select the songs from my hard drive.
Any help on this would be appreciated please, been trying to to this for a few weeks now without success, bring back trial version
geposted Wed 10 Feb 10 @ 12:19 pm
If you've purchased a legal copy of VirtualDJ, please register the serial in your profile. Doing so will get you access to the download centre so you can download the latest version.
A couple of things:
* The last Pro v5 version was v5.2.1; there was no v5.3 Pro to my knowledge.
* What version did you purchase and from where?
* What version are you actually using now?
* I would recommend connecting all hardware before starting VDJ.
* What is NG search? It's nothing to do with VDJ. It has it's own integrated browser and search engine.
geposted Wed 10 Feb 10 @ 12:25 pm
DJ azenPRO InfinityMember since 2008
let see how long it takes him to register the vdj.
geposted Wed 10 Feb 10 @ 1:38 pm
