Topic: Pitch Bend?
Where are the Pitch Bend buttons + / -?
how are we supposed to bend?
geposted Thu 14 Aug 03 @ 6:39 pm
DJ CocoPRO InfinityMember since 2003
you can create a pitch bend shortcut
geposted Thu 14 Aug 03 @ 8:12 pm
This function is critical for beat matching. With the DAC2/DMC1 the inner jog wheel could be used for pitch bend and for scratching
geposted Fri 15 Aug 03 @ 10:54 pm
Can you explain how to create a pitch bend keyboard shortcut.
geposted Tue 09 Nov 04 @ 5:44 pm
From the Setup menu, choose Keyboard Shortcuts, Add, press your favorite key for bending, category turntable, sub-category nudge, value +/-64 (choose a value you like for the amount of bend), select desk, choose OK.
Done
geposted Tue 09 Nov 04 @ 6:33 pm
djbambiPRO InfinityMember since 2003
wireless> with your XP10s, pitch bend is the outer wheel (turn the wheel without touching the middle)
geposted Tue 09 Nov 04 @ 7:24 pm
claxPRO InfinityMember since 2004
You can also use arrows keys to "nudge" if you haven't changed theirs functions.
geposted Tue 09 Nov 04 @ 7:39 pm
