Hello,
Since the 6.0.7 version, I've got a big problem using my CDJs 400 in HID mode.
When I'm trying to cue or to go back, then stop a song pushing the jog, then release the job to read the song, sound is speeding up then go back to good bpm (like old vintage low quality belt decks). So, it's pretty hard to chain music a descent way.
PS : I have the same problem on Mac and PC. If you do the same thing with the skin, it doesn't happend.
Perhaps it is a new way to support CDJs... But CDJs in native mode are not working like this.
Cheers
Cheers
geposted Wed 10 Mar 10 @ 1:14 am
I have exactly the same problem (with the same config; VDJ 6.0.7, 2 CDJ-400 and asio drivers) with or without the modifications of DJCell for the mapper.
geposted Wed 10 Mar 10 @ 6:02 pm
Same problem here, you can listen start to minute 4 but I have already informed Cstoll and I hope Team will fix in next release.
geposted Thu 11 Mar 10 @ 1:32 am
