Forum: Old versions
Topic: Pro Version 6.07
richlPRO InfinityMember since 2009
Just downloaded it and it doesn't work... at all..!!
geposted Fri 12 Mar 10 @ 8:55 pm
You'll have to be a bit more specific than that.
If it doesn't install then you likely have a corrupt download.
geposted Fri 12 Mar 10 @ 10:45 pm
Finally got it working after the 3rd download.. previous update from V6.05. What are the key differences..?
geposted Sat 13 Mar 10 @ 12:37 am
taylaPRO InfinityMember since 2007
geposted Sat 13 Mar 10 @ 2:45 am
Cheers tayla.. I really should use the forum more :)
geposted Sat 13 Mar 10 @ 4:02 am
tee hee, no probs mate.
geposted Sat 13 Mar 10 @ 4:25 am
