Forum: Old versions
Topic: Timecode BPM.
I have Serato 2nd edition vinyls, and Numark TTX turntables. When I adjust the pitch on the turntable, the sound of course changes but the BPM doesn't reflect the change. Are my settings wrong?
(note: using line-out and keylock on turntable)
geposted Sun 14 Mar 10 @ 11:19 pm
Which Version of VDJ Pro are you using?
geposted Mon 15 Mar 10 @ 1:25 am
The latest one 6.05 I think. I'm also using the turntablist v5.2 skin if that makes any difference.
geposted Mon 15 Mar 10 @ 5:25 pm
First I would register your Serial Code in your profile. that way everyone knows your a Pro user, and it gives you access to the newest version and increased support.
If you post exactly what your settings are, then someone can tell you if they are correct or not :-)
geposted Mon 15 Mar 10 @ 6:05 pm
Ok
geposted Mon 15 Mar 10 @ 7:27 pm
Ok
