Forum: VirtualDJ Skins
Topic: Mixlab v3 new Face and need Help! - Page: 1
Hi there, i want my personal skin and i testet a much functions.
But i have one Problem, see here:
The Problem is the Effects Parameter. I like to see the green lines in this.
But the Skin just chrashed and close.
Is tehre anyone who can programm it?
Cheers Max
geposted Thu 15 Apr 10 @ 12:05 pm
i can try fixing it though =)
just pm me and i'll help u
geposted Thu 15 Apr 10 @ 5:41 pm
Thx Dj Alex Jarocho...
K Mates i still have this Problem... no one can fix it.
Anyone here ? :)
geposted Thu 22 Apr 10 @ 10:52 am
aubs123PRO InfinityMember since 2006
you could try this
this is a tiny mod i made to the VIRTUALDJ6 TC skin by lolotte88
and this is the coding i used
</slider>
<slider pannel="Deck_1_Sound_FX_Main" action="deck 1 effect slider 1" orientation="horizontal" direction="right">
<pos x="104" y="319"/>
<size width="53" height="40"/>
<up x="104" y="319"/>
<selected x="104" y="319"/>
<fader>
<pos x="9" y="3029"/>
<size width="2" height="40"/>
</fader>
</slider>
<slider pannel="Deck_1_Sound_FX_Main" action="deck 1 effect slider 2" orientation="vertical" direction="up">
<fader>
<size width="53" height="2"/>
</fader>
</slider>
obviously you will have to change the x and y locations to match your skin and for the green box you add to the bmp file
the bottom width and height lines can stay the same as there for showing the lines inside the box
I'm no skinning expert but hope it helps you out a bit
aubs
geposted Thu 22 Apr 10 @ 2:32 pm
P421pHome userMember since 2009
Could somebody please help me? I'd like to download the mixlab 1.3 skin (not 3.1) but i can't do it. What is the problem and what should i do? thanks,
geposted Thu 22 Apr 10 @ 2:58 pm
taylaPRO InfinityMember since 2007
you need to be a full version user to do that i'm afraid.
geposted Thu 22 Apr 10 @ 3:00 pm
thank you,
is there any other option?
could sb. send me or upload the skin to another site? ( i couldn't find it )
geposted Thu 22 Apr 10 @ 3:15 pm
You need to purchase VDJ to enable skin downloads. Please don't ask other users to illegaly upload skins to file sharing sites.
Regards
Keith
geposted Thu 22 Apr 10 @ 4:12 pm
I see and sorry,
thanks
geposted Thu 22 Apr 10 @ 4:59 pm
No probs, all part of the learning process.
geposted Thu 22 Apr 10 @ 6:05 pm
big thx to aubs123
i got it :) ... not perfect but no errors and it rocks :)
Thanks Guys !
geposted Sun 25 Apr 10 @ 5:50 pm
coming bac to the topic of the function in this skin..
the little box you create are just sliders for the two fx parameters?
how does it work?
if i click inside the box, does it move the two sliders at the same time??
geposted Tue 27 Apr 10 @ 10:21 pm
@marksmolinski
Yes, all Effects Slider move at the same time.
But its crappy to program it =(
Now my next Question:
I like to see when the Track is going to the end.
In the VDJ 6 Skin there are blue points around the "Vinyl" ... how can i program it?
geposted Wed 28 Apr 10 @ 7:01 am
and now i will show u my skin :
What do you think ? Good Bad? Its not finished but i like it :P
geposted Wed 28 Apr 10 @ 3:00 pm
Update ... I got it :D
geposted Wed 28 Apr 10 @ 4:23 pm
Hey man thats a slick update!! You think I could get a copy of that??
geposted Wed 28 Apr 10 @ 5:05 pm
Thanx :)
Yes of course! ;-)
But i will fix some errors .. a few days and u have my copy ..:o)
**Update**
Master Number
and Master Level added
geposted Wed 28 Apr 10 @ 5:10 pm
Nice cant wait
Thanks for your time and keep up the good work
Huey
geposted Wed 28 Apr 10 @ 6:55 pm
DJ azenPRO InfinityMember since 2008
maxstell1
i tried and i like it a lot, but maybe is just me, in my:
te master volumeters does not show
the gain volumeters freeze if you changed to cue o sample, and still show in the video window (unless it's suppose to do that)
Good Work!!!!!!!!!!!.
geposted Thu 29 Apr 10 @ 9:02 pm
Nice job i like it alot good job..........
geposted Thu 29 Apr 10 @ 9:16 pm
67%
