how can i change it?
geposted Sun 17 Aug 03 @ 10:51 am
You need to edit the .xml file of the skin that you are using and choose a font that supports characters you wish to see.
Just open the file in notepad and anywere that it says font="Tahoma" put font="Arial"
(instead of Arial, put the font you want)
geposted Sun 17 Aug 03 @ 11:23 am
it dident work. what to do?
geposted Mon 18 Aug 03 @ 2:21 pm
Cry ;)
geposted Mon 18 Aug 03 @ 5:48 pm
can anybody help me?
geposted Tue 19 Aug 03 @ 9:29 pm
sorry but i don`t speak your language !
geposted Tue 19 Aug 03 @ 10:31 pm
yes, but maybi you can tell me what i need to do?
geposted Wed 20 Aug 03 @ 11:13 am
The answer is what Nscode said to you:
''You need to edit the .xml file of the skin that you are using and choose a font that supports characters you wish to see.
Just open the file in notepad and anywere that it says font="Tahoma" put font="Arial" ''
Try to open the xml file in Wordpad, if you have older
windows than 2000/XP
and use the find and replace command (Edit menu)
(Or maybe just ''replace'', as i see now in WinME)
Now where it say :find -->write: tahoma
and where it say :replace with -->write: arial
and press the''Replace all'' button.
Save the file.
I'm not sure about Arial
In my case (i'm Greek) i had to use: Arial Greek
And this is working for my language.
Try something similar.
See what font other programs (in your language) use.
Note: If you change the fonts once, lets say from
tahoma to arial, and want to try again for another font
you cannot use tahoma again (to find) because you don't
have any tahoma left in your file.
Try again to the original xml file, (maybe you need to reinstall)
Save the file.
geposted Wed 20 Aug 03 @ 2:18 pm
i did it - the font for hebrow is: "ms sans serif"
have fun
have fun
geposted Thu 21 Aug 03 @ 3:16 am
if it works fine, could you upload the xml file to the language plugins, please?
geposted Thu 21 Aug 03 @ 3:31 pm
