Forum: VirtualDJ Skins
Topic: Vertical song position?
Is there anyway to make the song position, with wave enabled to go vertical. like the scratch wave?
As I am trying to make a skin with the song position set to vertical and placed on the the far left and right of the screen.
Thanks.
geposted Mon 17 May 10 @ 2:24 pm
If you mean the song position (the one that shows the song progress) yes, it can be vertical but it will be weird to me. But if you mean the rhythm pannel that both decks are shown, this can not be done.
geposted Mon 17 May 10 @ 3:35 pm
Thanks for the fast reply, and it is the song progress i was after.
Just been having a headache trying to do it and thought it might not be possable.
Well I can kinda get one to work now, but just cant seem to get the wave form to show.
geposted Tue 18 May 10 @ 5:42 am
I believe u need to put the graphic part in vertical as well (the colored parts bmp file)
like jb said it would be a little weird
geposted Tue 18 May 10 @ 10:08 am
Thanks for the info as well Alex, will try and give it a go.
geposted Tue 18 May 10 @ 4:18 pm
Well thanks for the info all, but I just cant seem to get it to work - back to scratching my head again
geposted Thu 27 May 10 @ 3:20 am
