Forum: VirtualDJ Plugins
Topic: Two New Transitions: H-Blind and V-Blind
I've just uploaded two new video transitions.
They are simple 'blind' effects - H-Blind has horizontal blinds that move vertically, V-Blind has vertical blinds that move horizontally.
You can configure the direction of movement (up/down, left/right depending on transition) and you can configure the number of blinds from 1 to 100.
Once approved by Atomix they should be available in the plugins download section.
Please note that these are PC only at present as I no longer have access to a Mac for compilation and testing I'm afraid.
geposted Mon 17 May 10 @ 7:02 pm
Magic Scott, thanks very much, can't wait to use them.
Nice one, cheers!
Thanks Scott GREAT as usual!!!
Thanks Scott...
Joey....
Nice transitions Scott, but there is a small bug that also appears in some other transitions:
the right deck's aspect ratio isn't kept when crossfading the videos.
Thanks for pointing that out - which other transitions have the same problem? Just mine?
I will test them all this weekend.
I don't remember which ones have the problem.
nice work!
Thank you you're the best. You really need to be given credit because you're one of the only ones I see actually creating plugins for vdj.
great job as allways. Thank you Mr SBDJ !!!
