hi i just wanted to know if someone could make a skin for if its possible , instead of those peaks across the top have seperate wave forms like you have in those scratch panels , get rid of those spinning platters , and a few other things aswell , my comps about nakerd it takes 10 min to start and if i try to launch any programs it takes ages to load so i cant try to do it myself ( ive tryed it took 5 min to load the skin tool )
geposted Sun 23 May 10 @ 10:50 am
If you search the skins there are 1's with the features you've just asked about. Also their is 1 call "BlackSheep", its a bad ass skin that just might be the last 1 you ever use.
Huey
Huey
geposted Sun 23 May 10 @ 11:00 am
