A few quesitons to help me decide if the premium membership is worth it.
1. Over the last few months, before 6.1, Very few would actually download. Does it work any better?
2. Are the Groveshark songs on higher quality? I dont like to play anything thats encoded at less that 192k?
3. Can you tell the source? Grooveshark or the other places that net search use to get files from?
4. Can the Netsearch Cache Locaton be changed? I swtich an external HD to different computers. I would like the cache files to stay with the External HD and not the comptuer.
Thanks for the help.
geposted Wed 26 May 10 @ 6:20 pm
1. I have only had one failed stream in the week or so using Netsearch so I would say there is an improvment.
2. Whilst you can not 100% gaurentee the quality of 8millions tracks there are some things that help. Tracks supplied by record labels etc show up with a green tick next to the globe to indicate an original, good quality source.
3. Once subscribed. ALL audio files are from Grooveshark. Video files at the moment remain for previous sources.
4. You can't change the default cache folder. But you can move files onto an external hard drive. But you must remember to refresh the cache permissions every 30 days.
Hope that helps!!
@farhanashraf - why do you keep posting this everywhere!?? If you don't use netsearch then maybe there is no point. I don't know.
Hope that helps!!
geposted Wed 26 May 10 @ 6:35 pm
DJTOUCHDAN,
Thanks so much for the help!
geposted Wed 26 May 10 @ 6:43 pm
you can move to another drive?
i can copy to my external ? didn't know.....
geposted Fri 28 May 10 @ 1:30 pm
