i read on the faq for timecoded vinyls that i should ground the turntables to the computer instead of the mixer.
last weekend i played using an extra deck just for virtualdj and grounded it to my desktop. it worked very well.... but i don't plan on carrying a full tower plus a 17" inch tft display around.... so how should i ground the deck if i use a laptop?
peace, bernardo, portugal
geposted Mon 30 May 05 @ 1:37 pm
by the way.... i used an m-audio quattro .... worked fine :D vey happy with the whole thing.... except for taking my main computer out of the studio.
cheers
cheers
geposted Mon 30 May 05 @ 2:06 pm
i asked the same 1 month ago i think... they told me to unscrew one of screws at back of my laptop (near power plug in) and connect ground cables to it.
Today i get maya44USB and i think i'll get TCVs tomorrow.
I will do like this. hope i will work.
btw i will try to connect ground with screw to metal part of graphic card connector. it's the only which has hole for screw.
Dj Nikki
Dj Nikki
geposted Mon 30 May 05 @ 5:00 pm
xeon, does your laptop adapter have an earth connection?
geposted Mon 30 May 05 @ 5:49 pm
yes, it has, but it is only to adapter and not to laptop. Any i always plug it into power supply without earth because of noise.
Dj Nikki
Dj Nikki
geposted Mon 30 May 05 @ 6:09 pm
Find anything that is metal on the back of your laptop ór your external soundcard, and wire it your turntable's earth.
also check this link:
http://www.virtualdj.com/products/timecode/
geposted Thu 02 Jun 05 @ 3:00 pm
