Forum: VirtualDJ Skins
Topic: Using VDJ 6 Skins for Version 5?
Hey Guys
I recently bought the VDJ 5 Home Version and thought it would look like the Version of the VDJ 6 trial - but it didn´t, so I registered and downloaded the VDJ 6 Standard Skin.
But it´s not working, I always get an Line Error (Error in Line 1593, at 1024x600 and 1024x768; Error in Line 1662 at 1280x1024 and Error in Line 1660 at 1280x768)
Is there anything, I can do against this? And where is this xml File, I could´t find anyone with nearly as much as this lines...
but I want a Skin with such a big Fader as in the 6 Versions - maybe you could recommend such a skin to me?
thx
Smor
geposted Thu 03 Jun 10 @ 10:04 am
You can not generally use ver6 skins with lower versions. But you can do the opposite. You may still find a lot of skins for ver 5 in the download section.
geposted Thu 03 Jun 10 @ 10:22 am
VirtualDJ Home Edition 5 is based on VirtualDJ version 5, therefore v6 skins are not compatible with your version.
If you would prefer getting VirtualDJ Basic, that is based on VirtualDJ 6, has more features, but costs a bit more ($99), please contact us at the support:
http://www.virtualdj.com/contact/step2.html
geposted Thu 03 Jun 10 @ 12:33 pm
