Topic: Video Doesn't Work...........
I use AVI files in 720x480 resolution on Hi-Def LCD screens, the play fine in Windows Media and Win-amp. When I try the demo 3.0 the sound is fine but I either get no video or it will lock up the system when it does show video. I run an AMD Athlon2500+, 1 gig 3200 ram, NVidia fx5200 with 128mb ram video card with dual output (crt and s-video for the lcd's)..........Also can't find a "pitch bend" for monentarily +/- of the tempo. Does it not exist or can I just not find it?
geposted Thu 02 Jun 05 @ 5:07 am
Try to use a video with smaller resolution... 352x240 sounds good. I'm using MPEG1 files (they're easy to play for your computer) with this resolution and got no problems.
geposted Thu 02 Jun 05 @ 10:41 am
ALso the fx5200 is somewhat underpowered for this job, consider a newer, faster gfx card like the 6600GT
geposted Thu 02 Jun 05 @ 11:06 am
claxPRO InfinityMember since 2004
Pitch bend function exists in VDJ.
Have a look in the shortucts (options -> Add shortcuts).
You can also use the "Nudge" function (left & right arrows if you haven't changed them).
geposted Thu 02 Jun 05 @ 6:50 pm
