Forum: Old versions
Topic: Macbook Pro + Pioneer CDJ 2000's
Using macbook pro latest model with latest version of virtual dj,trying to load waveform on CDJ 2000'S mapper not working for me.I also had a hard time setting up the audio for both players,had to set up one as aggressive device is that the correct way or should it actually work with both CDJ 2000'S listed.
geposted Sun 20 Jun 10 @ 8:03 pm
Same problem contacted support no answer yet
Yup, pairing two devices to one aggregate device is the normal way you should setup all Pioneer decks on Mac.
