This is exactly what I am trying to do..basically crossfade bass from Deck 1 (Playing) to Deck2 (Coming in).
I have already mapped action eq_crossfader_low to a key in my keyborad however presseing that key does nothing.
I am using MixLab V3.1 skin, WinXp, VDj 6.0.8 (b231).
Please suggest how I can achieve this.
I already have read this topic many a times but cannot quite follow:
http://www.virtualdj.com/forums/107333/General_Discussion/Cross_Fading_Treble___Mid___Bass_Using_assigned_key____Help_anyone__.html
All helps are appreciated.
Cheers
Logan
Cheers
Logan
geposted Thu 24 Jun 10 @ 7:46 am
Ideally you would assign the command to a knob or fader on a midi device but if this isnt an option then you could try this.
Set up a keyboard shortcut for
"eq_crossfader_low 0%" this will be allowing ALL the bass from deck 1 and NONE from deck 2
"eq_crossfader_low 100%" this will be allowing NONE of the bass from deck 1 and ALL from deck 2
"eq_crossfader_low 50%" will allow both bass tracks to be heard
This would obviously require 3 keyboard shortcuts but it is the only way without a midi knob/fader.
geposted Thu 24 Jun 10 @ 7:50 am
Almost perfect. Thanks for explaining and give me the code to assign. I now have done this in my key board.
This is really good. However what I was wandering if it is possible to move the EQ crossfader slowly from one deck to another deck.
Thanks a lot again.
Cheers
Thanks a lot again.
Cheers
geposted Fri 25 Jun 10 @ 12:33 am
I can't think of a way to do that on a keyboard. I'll have a play around and see if I can think of something.
As I said before this function is best used with a knob or fader, maybe you could consider a midi controller??
Anyway- if I figure in out I'll let you know.
geposted Fri 25 Jun 10 @ 10:38 am
You can map two keys to the following two actions:
eq_crossfader_low -10%
eq_crossfader_low +10%
Use smaller values for slower movement.
geposted Fri 25 Jun 10 @ 12:26 pm
^^ what he said ^^
Just had the same thought when doing pitch bend button on my skin. Lol
geposted Fri 25 Jun 10 @ 2:25 pm
thanks to both of you guys and giving me food for thought...
on an another note.. which MIDI controller do you guys think I should look for in your opinion.
geposted Fri 25 Jun 10 @ 3:13 pm
It depends on your requirements and budget.
Hercules DJ Console RMX or the cheaper Hercules DJ Console MK4 are good options and popular choices.
They include everything you need, including built-in DJ sound card (For headphone pre-listening) and free VirtualDJ Console Edition which can be optionally upgraded to the full Pro at a discount.
geposted Fri 25 Jun 10 @ 3:19 pm
thanks for all these quick advice. Really appreciate it. You guys had helped me a lot. Let me start scripting.
geposted Fri 25 Jun 10 @ 10:57 pm
playing the script a little but.. this obviously works better:
eq_crossfader_low +1%
(will take the eq_crossfader_low from 0% to 100% as long as assigned button remained pressed, basically from left deck to right deck)
eq_crossfader_low -1%
(will take the eq_crossfader_low from 100% to 0% as long as assigned button remained pressed, basically from right deck to left deck)
I just hijacked my own thread.
geposted Sun 11 Jul 10 @ 10:59 pm
