Hey guys!
I'm trying to figure this one out, I've also searched the forums and wiki with no luck.
Is there a way of gradually reducing/increasing master volume with a one key-stroke. I can set the master volume to 15%, but then it just 'cuts' from ie. 100% to 15% in an instant. I'd like to make it more like fading, when I press it, it slowly reduces volume to 15%. This would be really easy to do with something like a 'while' loop, but I don't think something like that exists in VDJScript.
Any suggestion would be much appreciated, thx,
ZZ
ZZ
geposted Thu 01 Jul 10 @ 6:01 am
Sorry, it's not possible to do this automatically.
However, you could map it to two keys on your keyboard as follows:
master_volume +1%
master_volume -1%
Holding down the key will then cause the slider to move appropriately when the key starts to repeat.
master_volume +1%
master_volume -1%
geposted Thu 01 Jul 10 @ 12:56 pm
Thx for the info, I had a feeling this might actually be the real reason I can't get it to work.
The solution you suggested is what I'm already using, but as I occasionally work at some events, where there is a lot of talk-overs and plenty of switching between music and speech, I figured it'd be much easier just pressing one button and leaving it to the software to do the rest. Maybe in the future then :)
Just a quick idea that popped in my mind just now. Is there maybe something like a 'sleep' function in VDJScript?
We could then put it together something like this:
master_volume +1% & sleep 10ms & master_volume +1% & sleep 10ms & master_volume +1% etc.
Or is it too far fetched again? :)
geposted Sat 03 Jul 10 @ 5:09 am
You will need to ask in the wishes and new features forum: http://www.virtualdj.com/forums/18/Wishes_and_new_features.html
Currently it is not possibly to apply delays and/or loops to VDJscript actions.
geposted Sat 03 Jul 10 @ 5:01 pm
Maybe an alternative solution can to to have , for instance :
one desk playing with your track and the pfl off
one desk not playing with the pfl on
and to use the auto_crossfade function
Syntax
auto_crossfade (number of millil seconds)
Example :
auto_crossfade 2000 .. do a full crossfade gradually in two seconds
.. gradually change the crossfade to the other desk .. so if the the other desk is not playing , your volume gradually decrease
You can tune how it decreases with the crossfader_curve function
Syntax
Example :
geposted Sun 21 Nov 10 @ 4:36 am
