This is in regards to the RMX Skin by Bruno VT
I am running on a intel i3 with 4gb ram win 7 64bit with VDJ 6.1 pro Hercules RMX controler with newest drivers from Hercules.
For some reason if I choose the skin then try to exit (x) VDJ crashes. If I try to choose another skin after RMX Style is choosen it crashes. I don't think it is a VDJ or Computer problem I believe it to be the skin itself and would like to know if anyone else is having this problem. I really like this skin because of the exact layout of the keys.
Thanks
Thanks
geposted Thu 08 Jul 10 @ 2:48 pm
I have also tested this on my desktop amd quad qore 8gb mem win 7 x64. I didn't have VDJ on my desktop so I d/l'd the trial version and the same effect where is crashes on exit or on skin change. I really like this skin and I hope that the author can address this.
geposted Thu 08 Jul 10 @ 6:46 pm
I love this skin, hopefully the author will update it to work with 6.1...this skin got me excited about dj'ing again....
geposted Fri 09 Jul 10 @ 3:15 pm
Yes he did a great job on the controls and graphics. My only complaint is the wave bar that shows the beats are too faint and thin. Kinda hard to see.
geposted Fri 09 Jul 10 @ 6:45 pm
So am I the only one with this problem????
geposted Mon 12 Jul 10 @ 6:20 pm
no its a problem with the skin and version 6.1
geposted Mon 12 Jul 10 @ 6:34 pm
I have also issues with the RMX/Steel skin.
Fisrt of all It never starts with this skin, always in default skin.
Tried to change this with the register tool, no luck.
These issues started after upgrading to VDJ 6.1
freek
freek
geposted Tue 13 Jul 10 @ 2:30 am
I wonder if there is anyone that could update this skin to work with 6.1?
geposted Wed 21 Jul 10 @ 12:27 pm
we are looking for errors and we have a suspicion.
please be patience
please be patience
geposted Wed 21 Jul 10 @ 5:39 pm
Thank you for the reply and the work..it is much appreciated.
geposted Wed 21 Jul 10 @ 6:11 pm
if I try to choose a different style of skin, after the choice of skin STYLE RMX program is closed, I believe it is their own skin and I wonder if anyone is having this problem or if you already find a solution
geposted Fri 06 Aug 10 @ 6:39 pm
i know this is an old thread but i thought i would revive it to see if the crashing problems were resolved. This is my favorite skin to use on my rmx and would like to use it without worries. I am getting tired of the default rmx skin
geposted Mon 27 Dec 10 @ 5:36 pm
