I installed virtualdj v6.0.2 professional and it installed fine, but when i opened it, within 2 minutes the program closes and an error box comes up that says protection error 8, contact www.virtualdj.com/contact.
I am working on windows xp.
is there an easy fix to this?? please help!
geposted Fri 09 Jul 10 @ 11:54 am
You will need to do what the error says and contact support for further assistance - http://www.virtualdj.com/contact/index.html
geposted Fri 09 Jul 10 @ 12:04 pm
I'm having the same problem, Virtual DJ Pro version 6.0.2, and Protection Error 8.
Have you gotten a solution?
geposted Tue 02 Nov 10 @ 7:24 am
As above, please contact support.: http://www.virtualdj.com/contact/index.html
Nobody on the forums can help you with this problem.
Also, please update your software to the latest version - http://www.virtualdj.com/buy/index.html - v6.0.2 is an old and out of date version of the software and there have been many improvements, changes and new features since then.
For non-commercial home use, you can download VirtualDJ v7 Home FREE: http://www.virtualdj.com/download/free.html
geposted Tue 02 Nov 10 @ 11:08 am
