i got everything mapped except i cannot figure out the 2 scratch wheels and the joy stick for that matter, any help?
btw i just upgraded from vdj 5.3 (i think) and everything was working fine with 5 i could scratch and mix, (i deleted v.5 when i got v.6) now i just have that tiny detail of the scratch wheels and joystick (i want to map the joystick to work the tk filter) not working, and oh yea i heard the vdj 6 will light up my leds on the dm2 does anyone know how that works?
im using dm2midi
thanks in advance
im using dm2midi
thanks in advance
geposted Sun 11 Jul 10 @ 7:37 am
There has never been a VirtualDJ v5.3 (v5.2.1 was the last v5 version before we moved on to v6)
Please download and use the latest v6.1 trial http://www.virtualdj.com/download/trial.html
Unfortunately TK Filter cannot be controlled by MIDI because it uses a custom graphic user interface and does not support effect slider - It can only be controlled with your mouse.
Information on mapping can be found on the following page http://www.virtualdj.com/wiki/VDJscript.html along with examples including how to map a jogwheel with Simple MIDI Wrapper on the following page http://www.virtualdj.com/wiki/VDJScript%20Examples.html
You may need to make a definition file for this device to work correctly (Especially for LED's which Simple MIDI Wrapper does not support) - http://www.virtualdj.com/wiki/ControllerDefinition.html
geposted Sun 11 Jul 10 @ 4:03 pm
thank you
geposted Mon 12 Jul 10 @ 3:51 pm
please i want the action learn for the v and n scratch keys
geposted Sun 31 Jan 16 @ 3:34 pm
