Just looking around and found this at the top of the list, http://www.virtualdj.com/addons/4294/Filters.html, well I downloaded and installed but it doesnt show up in the effects section. I can see the "dll" and the name does appear but I cant turn it on. Any ideas on what I should do??
Thanks for looking and your time
Huey
Huey
geposted Thu 15 Jul 10 @ 10:34 pm
If memory serves he compiled this against a very specific runtime version.
I think it may have been this one from memory:
http://www.microsoft.com/downloads/details.aspx?familyid=766a6af7-ec73-40ff-b072-9112bab119c2&displaylang=en
geposted Fri 16 Jul 10 @ 4:14 am
I'm on XP SP3 and I have intalled Visual C++ 2008 & 2005 Redistributable Package but i have the same problem of beatbreaker1 :(
geposted Fri 16 Jul 10 @ 4:24 am
Hmmm........When I try to download the file I keep getting this error,
![](/image/65419/36979/100715-065745.png)
Any ideas?? I'm using Vista
Huey
@SBDJ, thanks for the name change also, lol.
Huey
geposted Fri 16 Jul 10 @ 6:58 am
Now thats what I like to see..A Team up!! ;-) No problem here with the Plug.Humm thats a Real unusual Result there "Beat". Maybe this has been causing other Problems as well ? Google to see why your getting this! but scott will know.
geposted Fri 16 Jul 10 @ 8:55 am
I should have been more clear, I get that error when I try to download what Scott posted. Sorry for the confusion.
Thanks for looking
Huey
Thanks for looking
Huey
geposted Fri 16 Jul 10 @ 9:08 am
Name change??
Which package did you download from that link, vcredist_x86.exe? Sounds like you downloaded the wrong version for your OS. You definately won't want the IA64 that you probably downloaded ;)
C, as I said above it's compiled against a specific version of the runtime library so you need to ensure you have that exact version installed. I'm sure it was the 2005 SP1 with ATL update I linked to above.
geposted Fri 16 Jul 10 @ 9:26 am
Hey thanks Scott, you were right I did download the wrong 1. It was vcredist_x86.exe that I needed. Maybe in the plugin description he should add that??
And yeah name change, I had posted "Effects Not Working" and someone (which I thought was you Scott) changed it to "Filters v2.0 not working".........well either way we got it worked out, lol!!
Thanks for your time
Huey
Huey
geposted Fri 16 Jul 10 @ 5:01 pm
On my Windows 7 the plugin work fine, in my other PC with XP no way :(
PS. The "title" of the topic was edit by me
geposted Fri 16 Jul 10 @ 5:07 pm
Hahaa, thanks!! Hope you get it sorted on your XP machine.
Huey
geposted Fri 16 Jul 10 @ 5:21 pm
Sweet!
geposted Fri 16 Jul 10 @ 6:22 pm
Filters v2.1 is out ;-)
If it doesn't load, perhaps you have to update some libraries:
Microsoft Visual C++ 2010 Redistributable Package (x86):
http://www.microsoft.com/downloads/details.aspx?familyid=a7b7a05e-6de6-4d3a-a423-37bf0912db84&displaylang=en
Web Installer DirectX End-User Runtime:
http://www.microsoft.com/downloads/details.aspx?familyid=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
geposted Sun 15 Aug 10 @ 1:50 pm
What is this bad joke?
DeclareParameter(
text,
VDJPARAM_STRING,
EParameter_Text,
"\r\n\r\n\r\n\r\n\r\n§§§ n00b XOR h4x0r? <.< §§§\r\n\r\n\r\n\r\n\r\n", // joke
255
geposted Mon 16 Aug 10 @ 1:09 pm
