Forum: Old versions
Topic: PFL function and "computer language code"
Hi, I am currently using a hercules rmx console. I was wondering how the "cue select" aka PFL button worked or how to midi map it. Im not sure of the command i think its headphone_mix or volume or something but its not working
geposted Thu 29 Jul 10 @ 10:01 pm
Yeah. I still cannot work it out. currently the command goes like
Key: PFL
Action: Headphone_mix 0
but there is no volume coming out of the headphones and also the "Cue Select" or PFL buttons rather are permanently turned on
Anyone whose used a Hercules RMX console can help out?
What I want it to do is play 50% of the cued deck and 50% of the master output. what should i do? I initially put headphone_mix 0 just so that I could see if any sound would come out of the headphones
You need to map the PFL button to: select
If you wish to control or set headphone mix, map this to a key on your keyboard (Or several keys with different settings, e.g: 0%, 20%, 40%, etc.), e.g:
headphone_mix 40% if you wish to hear PFL deck plus master.
