Hey guys.
I'm looking for someone who really knows their way around the VDJScript
Im currently using the Touch Pannel skin for VDJ and I have a Hercules RMX DJ controller
http://www.virtualdj.com/addons/7441/Touch_Pannel.html
I would like if i could map one of my RMX buttons so that it would switch between the "effects bank" tab and the "sampler" tab.
And then I would like it, if my DJC-buttons 1-6 would trigger different actions depending on, if the "effects bank" or the "sampler" is active.
Is this possibly? and if so; PLEASE help me with the VDJScript!
Thanks guys,
cheers
Thanks guys,
cheers
geposted Sat 31 Jul 10 @ 7:09 am
Chosse a button from your RMX and try this...
This cycles through Effects, Sampler and Cues Pannels to both deck 1 and 2 (One button for both decks)
cycle "mode" 3 & var_equal "mode" 1 ? skin_pannel "111" on & skin_pannel "1111" on : var_equal "mode" 2 ? skin_pannel "2" on & skin_panel "211" on : skin_pannel "3" on & skin_pannel "311" on
For two buttons (each one for each deck..
This cycles through Effects, Sampler and Cues Panels to Deck 1
cycle "mode" 3 & var_equal "mode" 1 ? skin_pannel "111" on : var_equal "mode" 2 ? skin_pannel "2" on : skin_pannel "3" on
This cycles through Effects, Sampler and Cues Panels to Deck 2
cycle "mode" 3 & var_equal "mode" 1 ? skin_pannel "1111" on : var_equal "mode" 2 ? skin_panel "211" on : skin_pannel "311" on
geposted Sat 31 Jul 10 @ 9:14 pm
So lets say you have 1 button which will do the following..
If sampler pannel is active it will play sampler 1
if Effect Pannel is on then it will activate the FX "FlangerHQ"
if Cue Pannel is on it will go to Cue 1.
Code..
var_equal "mode" 1 ? deck 1 effect "FlangerHQ" active : var_equal "mode" 2 ? deck 1 sampler 1 play_stop : deck 1 goto_cue 1
Code..
geposted Sat 31 Jul 10 @ 9:25 pm
btw ... one of my favorite skins !!!
I just hope that all the above actions could be assigned with the LE Edition that comes with your RMX, otherwise you will have to upgrade to Pro Version.
geposted Sat 31 Jul 10 @ 9:28 pm
i know this was a old posting, i was just trying to see if you can help me out i also have the RMX. but first how do i add effects amd samples, i have downloaded them to my laptop but when i click on the samples tab they are not there and the effects are the same. If its not too much can u give me step by step instructions. i guess you can tell im new to it all....thanks
geposted Wed 04 Aug 10 @ 9:55 am
Go here first...
http://www.virtualdj.com/forums/95136/Virtual_DJ_Plugins/Plugin_not_working__Controls_not_showing__DX_File_Missing_______Read_this_before_posting_____.html?page=1
or you can look at my blog, there's one or two tutorials there that may help.
geposted Wed 04 Aug 10 @ 10:24 am
Hey you guys,
I would like to switch between thee skinpannels using one button:
skin_pannel "DJC_slot_1_6" on
skin_pannel "loop_slot" on
skin_pannel "cue_slot" on
I don't quite understand how to set the colons and questionmarks here. Can somebody help me out?
Mr.D
Mr.D
geposted Wed 01 Jun 11 @ 5:57 pm
this action will cycle through those skin panels
skin_pannel "DJC_slot_1_6" on ? skin_pannel "loop_slot" on : skin_pannel "loop_slot" on ? skin_pannel "cue_slot" on : skin_pannel "cue_slot" on ? skin_pannel "DJC_slot_1_6" on
However, custom mapping is not available on LE versions. You will need to upgrade to Pro Full version at a discount by entering your LE serial number to this page ..http://www.virtualdj.com/buy/index.html
geposted Wed 01 Jun 11 @ 9:55 pm
