Topic: Denon dn-mc6000 Full Mixer / 4–deck MIDI Controller
DN-MC6000 Full Mixer / 4–deck MIDI Controller
http://www.denondj.com/DN-MC6000-P125.aspx
• Size 18.1"(w) x 2.0"(h) 10.0"(d) without rack ears
19.0"(w) 6U (d) rack mounting size
• Computer Independent 4-Channel, 8 Source Premium Digital Mixer
• Slim Tabletop design for various DJ applications and portability
• Includes 19" rackmount accessory kit for Mobile DJs
Optimized for *Traktor and *Virtual DJ users
• Intuitive 4 deck software control, with visible deck color change
• Real-time Matrix Operation, Analog Sources, USB MIDI & USB Audio
• Included USB Audio Interface (Soundcard) 2in/2out (stereo)
• MAC OSX Windows XP/Vista/Win7 Compatible
• New, 3-way Powerful Audio/Video Assignable cross-fader
• Newly designed, high resolution 105mm Touch-Sensitive Jog Wheel
• Smooth 100mm long Pitch Slider with high 14-bit resolution
• Pitch/Fader/Volume Lock function - holds the last known Audio value and position until the NULL point is reached again
• File browse navigation keys & rotary encoder file selector knob w/illuminated ring
• 8 (4 + 4) Hot Cue/Sampler buttons w/dual bank selector key
• Auto Loop Button w/ Beat Jump (Loop Cut)
• Manual Loop In/Out buttons
• Large size Cue & PLAY buttons
• Various EFX control, EFX keys & Parameter knobs
• Various GUI control, Mixer, Video, Scratch, Sampler, REC,
• Powerful Shift Key - used for various dual button operation
• Search Keys (<< >>) to advance around within the file
• Denon's legacy "PitchBend" keys
• Vinyl & Pitch Bend Jog modes
• SYNC key for beat matching between decks
• Key Lock on/off button with LED confirmation
• Matrix Input Assignment Selector Knob
• Selectable PFL input gain & program meters
• Independent CUE System (all channels)
• Split Cue function with Cue/Master pan knob
• High quality, high output Headphone Amp
• 45mm Channel & Cross Faders
• Independent Channel A-B Thru Switch (crossfader)
• Cross Fader contour adjustment
• Independent 3-Band Channel EQ w/Kills (High-Mid-Low)
• XLR Balanced & RCA Unbalanced Master Output
• Master Output Stereo/Mono switch
• Booth Output w/Source Selector & level control
• XLR & 1/4 TRS Mic Inputs
• Mic 3-Band EQ (High-Mid-Low) for Mic 1 & 2
• Mic Ducking & Built in Echo Effect for Mic 1 & 2
• Various Utility presets to customize user settings
• MIDI Mappable control surface (Faders, knobs and buttons) for other DJ applications
• Firmware upgradable over USB
• Solid Steel chassis construction
• Kensington lock terminal to prevent theft
• ECO standby mode (green, energy saving)
• AC adaptor powered
*Traktor LE included for Europe and Asia Pacific
*Virtual DJ LE included for America\\\\\\\\\\\\\\\'s & Canada
( not Europe and Asia Pacific) ???????????????? is this so.
The DN-MC6000 will be available fall 2010 with a U.S. MSRP of $949.99
geposted Mon 16 Aug 10 @ 6:39 pm
all so have the virtual dj logo on it
i think it is about £900 mark .
I wrote to the EU contact: info@dm-pro.eu
I thinkl when they receive many eMails they think about it ;-)
MAAAAANNNNNYYYY eMails ;-))
