why is the cpu so high on some skins and not others.
geposted Thu 02 Sep 10 @ 6:13 am
It will depend on the size of the skin. If the skin has a large bmp, because it has multiple pannels.
Or, if you run a skin maximised that isn't your native resolution this will increase CPU usage also.
geposted Thu 02 Sep 10 @ 6:38 am
thank you.!!!!!!!!!!!!!
geposted Thu 02 Sep 10 @ 12:51 pm
